Every time I startup my computer, I get this strange folder/application properties that pops up for Cfg or CFG.exe.? Is there anway to remove this?? Thanks for your help in advanced!
Pop-up?s like the one you describe become the most annoying as you are constantly closing them every single time you start up your computer.? It gets to be a drag and it just seems like a harmless settings error or incorrect installation.? In reality, the problem you are having with the cfg.exe and cfg display of folder properties is added by the W32/Bdoor-ZAR backdoor worm.
Try the steps below to remove your error that pop?s-up during startup and you should be opening up to a desktop without any annoying problems!
Do a scan with our faithful tool: Malwarebytes? Anti-Malware!
After your scan is complete, reboot and check for the error.
As a safety precaution, I recommend downloading and running a scan for SUPERAntiSpyware but you should be error free by this point!? Good luck!
One Response
Daniel Craig
June 11th, 2009 at 6:01 pm
1Hi there, I was looking around for a while searching for Articles On Safety Tips For The Computer and I happened upon this site and your post regarding CFG Folder/Application Properties during Startup | What the Tech, I will definitely this to my Articles On Safety Tips For The Computer bookmarks!
