Where can I download a removal tool for ANTIVIRUS2009 for free?? These pop-ups are so annoying and I can’t figure out how to remove the AntiVirus2009 program.? Please help!!
AntiVirus2009 has easily become one of the top infections of the year.? It has some trickery that allows it to slip onto unprotected machines and evade normal AntiVirus scans.? Try these steps to remove the AntiVirus infection and see if it helps with your pop-up problem!
1.? Download ATF Cleaner – run the .exe and choose the Select All option. Hit Empty Selected.? (Your next couple reboots may be slower then usual; this is normal)
2. Next Download Malwarebytes’ Anti-Malware– (One of my personal favorite programs!)? Click the .exe and run the setup to install the program.? Pay attention to make sure Update Malwarebytes’ Anti-Malware and Launch Malwarebytes’ Anti-Malware are checked off.? Exit the installation after it is complete and let it check for any significant updates.? Perform a full system scan and remove any threats and viruses it finds.? I would recommend saving a log to post on the forum just to make sure your 100% clean or just in case you still might be having some other issues!
This should take care of your infection and I hope to hear your pop-up free very soon!
