07 Apr
Posted by Hemal in Gadgets, Internet, Mobile Technology, Software
Where do I find the hotspot app for the palm pre plus?? I tried looking for it in my download apps but I do not see it so I don’t know where it is located.? Is it loaded in a different place or is it a setting I need to turn on?
Mobile HotSpot is the the app that sets the Palm Pre Plus away from the Blackberry or iPhone devices.? No other smartphone makes it as easy as the Mobile HotSpot application on the Palm Pre Plus to share an internet connection for up to five devices!
Having trouble finding the actual app?? Well it might not be downloaded so we’ll use the app store to get the application straight to your phone.
The first step is to start the launcher in the bottom.? The launcher is the arrow up looking icon on the bottom right hand corner of your screen.? You can try to swipe across the screens horizontally and then search each screen vertically to find the mobile hotspot app, the icon is a ring with an antenna and some broadcasting signals, but if you have looked and do not have the item, we’ll download it from the app store.
Look for the App Catalog icon (white shopping bag) and click on the icon to confirm your selection.? In the search bar right at the top of the app, type in “Mobile hotspot” and click search to the right.? Be patient and watch as the applications that match that search term appear on the screen.? The first application should say “Mobile HotSpot” — Free and have a 5 star rating or something similar.? Click the icon and download to your phone!
Tap the program to launch it and create your new network!? I highly recommend you encrypt it with a password as it will make the network safer and keep unwanted visitors away.
10 Responses
Robert Olmstead
April 11th, 2010 at 8:54 am
1I have searched and searched for that app on my new phone and it is not anywhere in the catalog!!! I’m paying for this app and I can’t use it, because I can’t find the damn thing!!!
smelty smelter
April 12th, 2010 at 4:22 am
2dude, i know. i can’t find it either. and i can’t find pandora. there’s some kind of stuff going on.
katy
April 14th, 2010 at 7:49 pm
3I would like to know also I cant find either also and I am beginning to hate this phone
matt
April 16th, 2010 at 10:21 pm
4I can’t find it either, pandora or hotspot. Starting to get really annoying
Tyler
April 20th, 2010 at 4:52 pm
5Same here, just got it today, if i could get these apps, it would be awesome but theyre not in the catalog, im about to call the people
Tyler
April 20th, 2010 at 5:00 pm
6so i just called, the guy said that you have to update the device first, slide over to the “updates” icon and push it, afterward you should be able to get what you need! WOW I SOLVED A PROBLEM ON THE INTERNET! that is, if this works, im still updating
Tyler
April 20th, 2010 at 6:05 pm
7guys it worked!!!! do that
Ericka
April 21st, 2010 at 5:05 pm
8The mobile hotspot app (for Verizon) is FREE. it’s included in your data plan so you’re not just paying for that separately.
Ericka
April 21st, 2010 at 5:06 pm
9Is the update you did for the software?
Monyca
April 24th, 2010 at 6:46 pm
10Someone mentioned this in an earlier comment, but it took me a while to figure it out, so I hope this helps:
Ok, for everyone who can’t find Pandora or the mobile hotspot app – I was having the same problem when I first got my Palm Pre. I finally took it back to the Verizon Store – here’s what you need to do: Go to “updates” in your launcher. It looks like a yellow gift box with a red ribbon.
Let it run the updates. It takes 20-30 minutes. Then it has to install and restart your phone. At the end, the hotspot is there in your launcher and Pandora (along with a lot of different apps) are now in your app store.
It made me feel a LOT better about getting this phone. Also, I can’t believe the guy on Verizon tech support didn’t know to do this!
Tech Questions?
Categories
Links
Expert Zone
Support Forums
All trademarks and copyrights on this page are owned by their respective owners.
What the Tech is powered by WordPress - © Geeks to Go, Inc. - All Rights Reserved - Privacy Policy
